Go Back   NewCelica.org Forum > Celica Discussion > Audio, Electrical, & Security
Audio, Electrical, & Security Install & Protect Your System Here.
Old 10-31-2011, 10:11 AM   #1
Xtra Big Kahuna
Fog light wiring help
Okay so I installed some autozone fogs that just went right into the battery and now when I run them the alternator runs. Is there a way to plug them into the existing fog light connectors so the alternator wont run?
Sent from my DROID BIONIC using Tapatalk
Xtra Big Kahuna is offline   View this Members' Photo Gallery Reply With Quote
Old 11-02-2011, 04:25 PM   #2
The alternator runs whenever the engine does.
So, you'll have to be a bit more specific.
Old 11-03-2011, 11:21 AM   #3
Xtra Big Kahuna
When ever I turn on the fogs you can hear the alternator start to whine
Old 11-03-2011, 11:45 AM   #4
daduc
What i did was just splice the wires from those autozones into the original harness your comes stock with.
daduc is offline   View this Members' Photo Gallery Reply With Quote
Old 11-03-2011, 12:14 PM   #5
Is this the only time when you can hear it?
Old 11-03-2011, 12:30 PM   #6
Xtra Big Kahuna
Yes this is the only time I can hear it. I was going to tap into the stock fog plugs but I dont have the stock fog light switch
Old 11-04-2011, 07:31 AM   #7
I would double check how you currently have things wired. Make sure there is a decent connection to the battery.
I cannot advise you to hook them up to the stock wiring w/o knowing their power. Anything over stock 55W & it would not be advisable.
Old 11-05-2011, 09:06 AM   #8
SpikedCola
Send a message via Skype™ to SpikedCola
Do you hear the actual alternator itself whine, or alternator whine in the speakers?
2003 Celica GT-S
SpikedCola is offline   View this Members' Photo Gallery Reply With Quote
Old 11-05-2011, 12:47 PM   #9
bluhawk
Send a message via AIM to bluhawk
why not add a relay? Seems your light is drawing too much current.
bluhawk is offline   View this Members' Photo Gallery Reply With Quote
Old 11-05-2011, 01:14 PM   #10
Xtra Big Kahuna
I have a relay. They are either 65 watt or 55. Can't remember which. And it is the actual alternator whining.
Old 11-05-2011, 04:36 PM   #11
Can you turn the fogs on w/o other lights? If so, does it whine w/just the fogs?
I'm thinking you are tapped into something you shouldn't be.
Old 11-05-2011, 11:18 PM   #12
Xtra Big Kahuna
I can turn the fogs on and off when I have my headlights on and it only whines when I have the fogs on for an extended period of time. Like 10ish minutes.
I have the fogs wired directly to a relay which is connected to the battery and a switch inside the car.
Old 11-06-2011, 12:14 PM   #13
Are you running ICE? How healthy is the batt?
Old 11-06-2011, 09:30 PM   #14
ginobendezu
i got my 4inch fogs spliced to my drl. so they come on as soon as my car starts ( i do nt have stock fogs)
ginobendezu is offline   View this Members' Photo Gallery Reply With Quote
Old 11-06-2011, 11:35 PM   #15
Xtra Big Kahuna
What is ICE? Im not sure about the battery. Ya mine are just hooked to a switch and can only come on with the parking lights or headlights. Kind of a bummer sometimes. I will probably rewire them soon
Old 11-07-2011, 03:51 PM   #16
ginobendezu
did you tap into a power cable? i dont have mine wired to a switch, figured it doesnt matter if they are on full time since it'd be safer
Old 11-07-2011, 04:20 PM   #17
What is ICE?
In Car Entertainment
Running a stereo/amp?
Old 11-08-2011, 08:16 PM   #18
Xtra Big Kahuna
The switch is tapped into the cigarette lighter and I am running ICE. Its only an aftermarket head unit with the stock speakers I believe.
Old 11-09-2011, 05:34 AM   #19
If that's the case, you should be able to turn them on at any time.
Old 11-09-2011, 10:38 AM   #20
Xtra Big Kahuna
Its tapped into the light for the cigarette light
Old 11-12-2011, 12:47 PM   #21
The solid Green wire I hope?
Old 11-13-2011, 09:38 AM   #22
Xtra Big Kahuna
yep.
Old 11-13-2011, 09:13 PM   #23
ginobendezu
hows your alternator/ battery. your battery could be kinda weak so alternator might b kicking in. idk if it might work like that but im just guessing.
Old 11-13-2011, 09:38 PM   #24
Xtra Big Kahuna
Im guessing my battery may be a little weak. I just got the car about a year ago or less from a dealer and I doubt they would swap a new battery in. How would I check the battery. Sorry I am not much of an electrical guy.
Old 11-14-2011, 04:45 PM   #25
If its the original..... its time for a new one.
Old 11-14-2011, 04:51 PM   #26
Xtra Big Kahuna
I have no idea if it is the original. All I know about it is that it is from AC Delco.
Old 11-15-2011, 06:17 PM   #27
rg3777
VVTL-OL
I doubt anyone has the original battery. If it was it would say Toyota. AC Delco is GM. You need a volt meter to test the battery. It should be reading close 12.5v to 13v when off and about 13.5v to 14.5v when the engine is on. If it is under 13v when the engine is on it means it is not holding a charge and will die soon. Especially if you listen to the radio with the engine off for a long period of time.
01 GT 2ZZ C60
SKunk2 |MWR | Circuitworx | EnergySupsension | Hondata | Amsoil | Fidanza | CompetitionClutch | TRD | Custom Test Pipe
rg3777 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-15-2011, 07:15 PM   #28
Xtra Big Kahuna
Alright. I tested it with a volt meter awhile ago and it was around 12.45v. I can't remember if it was on or not. I will test it again tomorrow.
Old 11-17-2011, 06:32 AM   #29
it is from AC Delco
Not original
