Go Back   NewCelica.org Forum > Celica Discussion > Suspension & Brake Tuning
Celicas For Sale
Old 12-18-2006, 07:47 AM   #1
S|Lv3rBu||et
...is 99.999% empty space
Send a message via AIM to S|Lv3rBu||et
Spring Rate Database
Just an idea:
Can we put together a list of all the lowering springs (coil-over and otherwise) available for the
celica and their corresponding spring rates and the manufacturer claimed drop? I'm looking for a different set of springs currently and I've noticed the rates can be somewhat hard to come by. Just kindof thought one main list would be a good thing.
I'll get it started:
Bilstein
PSS Coilovers: 285 lb/in front and rear
C-One
Sport Springs: F: 258 lb/in R: 364 lb/in 1.3"
SS Coilovers: F: 448 lb/in R: 560 lb/in
Type-R Coilovers: F: 560 lb/in R: 560 lb/in
D2 Coilovers:
Front: 7 kgr/mm (392 lbs/in)
Rear: 5 kgr/mm (280 lbs/in)
Eibach
Sportlines
F: 178 lb/in 1.8" / R: 208 lb/in 2.4" (progressive spring rate)
Pro-Kit
F: 150 lb/in 1.2" / R: 203 lb/in 1.1"
Espelir
F: 168 lb/in 1.2" R: 213 lb/in 1.2"
Ground Control Coilver Kits
#8016 kit
front:250lbs/in rear:420lbs/in
Custom Ordered Spring Rates Available:
200 lb/in - 700 lb/in
Hotchkis
F: 164-242 lb/in 1.375" R: 1.875" 350-380 lb/in (progressive spring rate)
TVS coilovers:
F: 300 lb/in R: 450 lb/in
JIC Magic
SF-1 Coilover
F: 336 lb/in R: 448 lb/in
Ksport
Kontrol Pro F:392 lb/in R:336 lb/in
KW
Variant 2 Coilovers:
F: 340 lb/in R: 340 lb/in
Megan Racing
F: 250 lb/in 2.0" / R: 230 lb/in 1.9"
Progress Tech
F:1.6"/180 lb/in R: 1.8"/230lb/in
RS*R
Down
F: 178 lb/in 1.6" / R: 226 lb/in 2.0"
Skunk2
F: 84 - 190 lb/in 1.4" R: 117 - 229 lb/in 1.4" (progressive rate)
Adjustable Coilovers:
F: 446 lb/in R: 335 lb/in
Swift Springs
Sport Mach
F: 111-185 lb/in 1.2" R: 151-213 lb/in 1.0" (progressive spring rate)
Tanabe
Sustec Pro S-S Type I&II
F: 336lb/in R:336lb/in
DF210
F: 2.2", 145 lb/in R: 2.5", 235 lb/in
GF210
F: 162 lb/in R: 223.5 lb/in 1.5"
NF210
F: 145 lb/in R: 190 lb/in 1.5"
Tien
S Tech F:168lb/in R: 224lb/in F/R 1.4"
H Tech F: 145 / R: 207 F: 0.8" / R: 0.8"
SS Coilover: F:280 R:390
SSP Coilover: F:390 R:500
Basic Coilover: F: 280 R: 390
Tokico
HP Suspension Kit
F: 145 lb/in R: 250 lb/in 1.25"
TRD
Coilovers:
F: 200 lb/in R: 350 lb/in
Toyota
Stock:F: 136lb/in R:168lb/in
Trial
Max Coilovers
F: 559.5 Lb/In R: 671.4 Lb/In
Weitec
F-Series Springs
F: 341 lb/in R: 341 lb/in 1.6"
Whiteline
Control & Flatout Springs
F: 176 lb/in R: 252 lb/in
Zeal
Function-X
F&R: 448 lb/in
Feel free to add info if you have some!
S|Lv3rBu||et is offline   View this Members' Photo Gallery Reply With Quote
Old 12-18-2006, 10:37 AM   #2
D_CeLiRaToR
D_CeLiRaToR
tein basic coilover are also F:280 R:390
D_CeLiRaToR is offline   View this Members' Photo Gallery Reply With Quote
Old 12-18-2006, 12:06 PM   #3
S|Lv3rBu||et
Cool, I updated my list, and I think I'll be calling/emailing a few manufacturers to try to get their spring rates as well.
Old 12-18-2006, 02:44 PM   #4
jakbauerctu
anyone know what the stock rates are? it would be good to add those to the list for comparison.
When you open up a can of kick-ass..... Jack Bauer jumps out!
jakbauerctu is offline   View this Members' Photo Gallery Reply With Quote
Old 12-18-2006, 04:59 PM   #5
Blue Bomber
No More Heroes Otaku
Stock: 0.0/0.0 - 136/168
Eibach Pro Kit: 1.2/1.1 - ?/?
Eibach Sportline: 1.8/2.4 - ?/?
TRD: 1.25/1.25 - ?/?
Hotchkis: 1.4/1.9 - 200/365
H&R - 1.3/1.3 - ?/?
Progress Tech: 1.6/1.8 - 180/230
C-One: 1.4/1.4 - ?/?
Tanabe Superdown: 2.1/2.4 - ?/?
Tanabe DF210: 2.2/2.6 - 145/235
Old 12-20-2006, 06:59 AM   #6
S|Lv3rBu||et
H&R - 1.3/1.3 - ?/?
Thanks christian, I knew you'd have some good input on this one!
Old 12-21-2006, 03:29 PM   #7
deltaB
1zz-2zz(mrs-gts)
Has anyone figured out our motion ratios so these can be translated into suspension frequencies?
I used to write all of the spring rates down as I wandered across them. I think the compilation has been done before.
BTW: I remember the sportivo front was the stock rear at 168.
Here's a 2002 discussion http://www.newcelica.org/forums/showthread.php?t=10953
dB
deltaB is offline   View this Members' Photo Gallery Reply With Quote
Old 01-02-2007, 09:35 AM   #8
TW00Si
The Street
Send a message via AIM to TW00Si
This should be stickied if not already.
07 GPW S2000
03 Black Celica GTS Sold
TW00Si is offline   View this Members' Photo Gallery Reply With Quote
Old 01-03-2007, 01:02 PM   #9
S|Lv3rBu||et
That would make sence if could get together a sizeable list...
Old 01-03-2007, 05:09 PM   #10
d's gts
Fried Tofu
found this on another thread-
trial max coilovers
F: 12 Kg/mm = 671.4 Lb/In
R: 10 Kg/mm = 559.5 Lb/In
d's gts is offline   View this Members' Photo Gallery Reply With Quote
Old 01-04-2007, 05:31 AM   #11
S|Lv3rBu||et
trial max coilovers
Nice find, and MAN, those are some hard springs!!
List updated!
Old 01-04-2007, 01:34 PM   #12
Franky_RedWine
GT-Turbo stage1
Zeal Function-X
Spring Rate:
Front: 8 kg/mm
Rear: 8 kg/mm
Spring Length:
Front: 178mm
Rear: 152mm
Franky_RedWine is offline   View this Members' Photo Gallery Reply With Quote
Old 01-04-2007, 03:02 PM   #13
S|Lv3rBu||et
Originally Posted by Franky_RedWine
Zeal Function-X
Spring Rate:
Front: 8 kg/mm
Rear: 8 kg/mm
Spring Length:
Front: 178mm
Rear: 152mm
Sweet, list updated!
Old 01-04-2007, 03:24 PM   #14
icanhascheezburger
Nice thread with very good info.
Old 01-04-2007, 04:16 PM   #15
gts_rosh
Oh cool, finally! I've been waiting for this kinda info for a long long time. Let's see what's missing that I can contribute:
The NEW RS*R Down Lowering springs:
1.6"F / 2.0"R is 178F/226R
The NEW Megan Racing Lowering Springs:
2.0"F / 1.9"R is 250F/230R - There is a typo on there website, I had emailed them to verify the spring rates, and its suppose to be 250/230 instead of the wrongly published 275/250.
I wrote down from some article that the Eibach Sportlines is:
1.8F/2.4R - 178R/208R (but I know that might be wrong, since its a progressive spring and should have a rating similar to the Hotchkis.)
gts_rosh is offline   View this Members' Photo Gallery Reply With Quote
Old 01-04-2007, 04:17 PM   #16
wacko604
anyone know the spring rate for the H&R's?
www.celicagarage.com
wacko604 is offline   View this Members' Photo Gallery Reply With Quote
Old 01-04-2007, 04:28 PM   #17
gts_rosh
One more thing, I'm guessing the TRD Lowering springs is the following rate:
160F & 212R
Because they make that same drop in springs for the Scion TC at 1.25" drop and they state that TRD made the front 18% stiffer & 26% stiffer in the rear...which I'm guessing might be the same on the Celica. So I increased the F & R by 18% & 26% respectively.
Old 01-04-2007, 10:33 PM   #18
Carbonized_GT
ASE Certified Moron
Tanabe Sustec Pro S-S Type I and Type II- F:6kg/mm R:6kg/mm
Hellafunctional- For the 'haters' like me.
Rx8 For Sale
Old 01-05-2007, 06:42 AM   #19
S|Lv3rBu||et
Great info! List updated!
Old 01-05-2007, 06:53 AM   #20
S|Lv3rBu||et
160F & 212R
Well, that does make sence and all... can anyone confirm or disconfirm this??
Old 01-12-2007, 09:42 AM   #21
MicaCeli
Now with Mo CAMABA
Stickyfied
00&03 Celica GT-S's|1991 Miata| 2x87+88 NA & 88 S/C MR2's|2002 Yukon XL|project:BDR
MicaCeli is offline   View this Members' Photo Gallery Reply With Quote
Old 03-12-2007, 09:45 AM   #22
Wilke
clever phrase here
Ksport Kontrol Pro F:392 R:336
Wilke is offline   View this Members' Photo Gallery Reply With Quote
Old 03-17-2007, 04:27 PM   #23
S|Lv3rBu||et
^^ Whoa!
Those are some high spring rates!
Updated...
Old 03-26-2007, 02:24 PM   #24
S|Lv3rBu||et
List updated with Eibach Pro-Kit info!
Old 03-27-2007, 11:30 AM   #25
S|Lv3rBu||et
List updated with Swift Sport Mach springs!
Old 03-31-2007, 08:44 AM   #26
deltaB
1zz-2zz(mrs-gts)
Whiteline 176F - 252R
From the whiteline forum:
Spring Rate of 73173, 73174
Originally Posted by Wojtek
Hi Gordon,...
Spring information requested:
73173 - 176 lbs/in (3.1 kg/mm)
73174 - 252 lbs/in (4.5 kg/mm)
Whiteline is in charge of design, testing and manufacturing of Whiteline springs. We do not copy, modify or use any other brand of springs.
Regards,
Wojtek.
Old 03-31-2007, 10:49 AM   #27
S|Lv3rBu||et
^^ Nice! Do we know if that is for their 'control' or 'flatout' spring?
I'll contact them and see if I can't find out.
Edit: Looks like it's the same rate for both!
List updated!
Old 04-03-2007, 09:15 PM   #28
Tommy2k17
Skunk2 racing lowering springs
Not sure on the rate but here is a link for the springs.
Modifications:
cold air intake, TRD exhaust, short throw, skunk2 lowering springs, tie bars all around, Greddy E-manage ECU, AEM underdrive pulley system, lightweight flywheel from monkeywrench racing, stage 3 racing clutch, 4 into 1 after market header, 16" prymax 618 style rims wrapped with 205/40 negotiator tires
Tommy2k17 is offline   View this Members' Photo Gallery Reply With Quote
Old 04-04-2007, 07:04 AM   #29
S|Lv3rBu||et
^^ Found the info one Skunk2s website.
List updated!
Old 04-20-2007, 05:18 PM   #30
The__J__Factor
C-one SS is 8-10kg and c-one type R is 10kg 10kg
2007 ///M Coupe
Rotrex Celica 300+whp - Now Sold
The__J__Factor is offline   View this Members' Photo Gallery Reply With Quote
Old 04-21-2007, 06:54 AM   #31
S|Lv3rBu||et
Another set of super hard springs!!
List updated, thanks
Old 04-26-2007, 02:28 PM   #32
S|Lv3rBu||et
List updated with the Tokico HP suspension kit!
Old 04-27-2007, 12:20 AM   #33
itchyvi3t
KW variant 2 coilovers 340/340
also need to get:
ground control coilovers
trd coilovers and sportivo setup
progressive springs
current mod: stock
itchyvi3t is offline   View this Members' Photo Gallery Reply With Quote
Old 04-27-2007, 07:05 AM   #34
S|Lv3rBu||et
Nice, list updated!
also need to get:
progressive springs
Be my guest
Old 04-27-2007, 07:11 AM   #35
Scratchy
Space Clown
Hotchkis TVS coilovers (now discontinued) with linear Hyperco race springs: 300F 450R
Scratchy is offline   View this Members' Photo Gallery Reply With Quote
Old 04-27-2007, 07:12 AM   #36
Scratchy
Space Clown
TRD coilovers 200F 350R
Old 04-27-2007, 08:15 AM   #37
S|Lv3rBu||et
List updated.
Old 04-27-2007, 08:18 AM   #38
S|Lv3rBu||et
Thanks Scratchy, list updated!
Old 04-27-2007, 10:33 AM   #39
S|Lv3rBu||et
I'm actually pretty pleased with how the list is coming along, we have all the popular options covered, and we're even getting a good amount information on the exotic parts! Keep 'em coming everyone!
Old 05-07-2007, 07:04 AM   #40
zycha
USDM GT-S
Weitec F&R 6.1kg/mm
zycha is offline   View this Members' Photo Gallery Reply With Quote
Old 05-07-2007, 08:54 AM   #41
S|Lv3rBu||et
Originally Posted by zycha
Weitec F&R 6.1kg/mm
Thanks for the info, but I cannot find these springs for sale anywhere!
Do you have a link for this product at all?
Old 05-07-2007, 09:24 AM   #42
zycha
USDM GT-S
It is euro manufacturer from KW group. www.weitec.com
This site visiting more and more ppl from Europe.
I have Weitec + AGX on my GT-S.
Old 05-07-2007, 10:27 AM   #43
S|Lv3rBu||et
Alright, found it. Thanks again!
Old 05-07-2007, 10:31 AM   #44
Friced
Light foot speeder
Has anyone heard of rennsport springs for the celica?
I've never heard of them before, are they any good?
2005 Toyota Celica GT-S
Friced is offline   View this Members' Photo Gallery Reply With Quote
Old 05-08-2007, 06:59 AM   #45
S|Lv3rBu||et
If you've never heard of them, how is it possible that you're asking about them?
No, this is the first I've heard of Fennsport as a company.
Old 05-08-2007, 07:52 AM   #46
Friced
Light foot speeder
Hey! stop trying to be difficult
Ok, I guess I shouldnt buy them off a guy then.
Old 05-18-2007, 09:32 AM   #47
Wilke
clever phrase here
Skunk2 springs have progressive rates and sould be
f:84-190lb/in -1.4"
r:117-229lb/in -1.4"
Skunk2 coil sleeves - f:446lb/in and r:335lb/in
Old 05-19-2007, 07:20 AM   #48
S|Lv3rBu||et
f:84-190lb/in -1.4"
Ahhh, so that's what they mean by "tender" and "main" spring rates! Updated.
Old 05-30-2007, 06:59 AM   #49
S|Lv3rBu||et
List updated with C-One sport springs.
Old 05-30-2007, 02:17 PM   #50
d's gts
Fried Tofu
on the c-one springs add
vB code is On
