Thread Tools | Rate Thread | Display Modes |
#1 |
Sponsor
* HELLA Designed HID Conversion Kit (Chinese New Year GB)
* Free shipping to anywhere in the world ** EDIT Group Buy extended till 2.28.07!! *** 30 days money back gurantee, if you are not satisfied with the HID kit As long as they are returned in new condition Conversion kit includes : - Ballast designed by Hella in Germany - Bulb from Super Vision - Wires, harness and mounting bracket - Exports to Japan!! Single-Beam Bulb size available in Celica uses H7 H1, H3, H7, H8, H10, H11, H13, H4, 9004, 9005, 9006, 9007 Bi-xenon Bulb size available in (Retractable/Sliding bulb) For cars with high an low beam in one bulb H4/9003, 9004, 9007, H13 Color Temperature Available - 3000k [+$30] (Hyper Yellow) Pure yellow color, it will bother on-comming traffic, buy at your own risk!! - 4300k (Slight yellowish white) Maximum visibility - 6000k (Pure white) Most white with great visibility (I recommand this color) - 8000k (Bluish white) Little bit of blue with good visibility (If you want little blue get this) - 10000k (Blue white) More blue color but adequet visibility, still brighter then stock halogen - 12000k (Blue Purple) Most colors, but visibility will be compromise, especially in rain [Special Order only] Price List : - Single-beam Conversion Kit : $180 - Bi-xenon Conversion Kit : +$70 Ordering Information : ORDER DIRECTLY FROM LEDMOD.COM'S ONLINE STORE HERE!! * Price has been adjusted for this Group Buy Delivery time 7-10 days Installation Guide - For Toyota Celica 00 and up ![]() ![]() ![]() ![]() Warranty information - Ballast and bulb has 1 year warranty Technical Specification: Bulb Output 35 watt Nominal voltage 85 volt Operating temperature −40°F-185 °C Lifetime >2000 hours High voltage ballast Operational input voltage 9−16 VDC Maximum input current 10A Minimum voltage loaded (lamp on) 60V Maximum voltage loaded (lamp on) 120V Output voltage from ignitor Nominal voltage 23 kV Minimum voltage 18 kV
LEDmod.com [LED modified] Toll Free 888-477-4944 NEW Store Location in Buena Park, CA!!! Custom Gauge Face and LED Lighting HID Conversion Kit with Slim ballast Local installation service available in Southern California and Las Vegas Last edited by LEDmod : 02-22-2007 at 12:05 AM. |
#3 |
no options celica
hey dooly i wanna get these for my dad's 99 camry. but i want to know if these would be plug and play or do they only fit the celica?
![]() TRD coilovers, TRD f&r sway bars, TRD exhaust, AEM cold air, TWM short shifter, Cusco tie bar, ES motormount, ENKEI OR52 18" |
#4 |
#48 Chino Hills '07
what's the difference between single beam and bi-xenon? and are these just plug and play?
#6 | |
hookah me up
I'm interested in a pair, but it isn't for the Celica, it is for an E39 BMW (03 5 series). So, will it cause the Check Front Headlight warning to come on, like the China-made ballasts do, or does it correct it like the OEM Hellas do?
Anyways, if they will work with the Bimmer, put me down for a pair of H7s @ 6000k. |
#9 |
I BUILD SLEEPERS
email sent ...
#10 | ||
ditto
#11 |
wat's the warranty on this Sean?? and how long will the sale last?? or when will it end..
Buy my PARTS..Need it all Gone: http://www.newcelica.org/forums/showthread.php?t=301285 |
#12 | ||||||||
Sponsor
It would need Bi-Xenon HID kit $250 shipped... Paypal : Sean@LEDmod.com Please include which size, color and phone number!! Quote:
Bi-xenon kit come with single HID bulb with sliding mechanism to act as low and high beam by sliding in and out... This kit will be plug and play.... Quote:
2. They have good reliability for it's price... it's better then most eBay HID kit, but not as good as thos OEM type HID, like Denso, Ma****uta etc.. 3. They are pretty easy to install, for Celica they don't require to remove the bumper, but it makes it easier to install them with bumper and headlight removed... removing the bumper and headlight is very easy.... it makes mounting the ballast so much easier with those removed... It will be hard to mount the ballast without removing the headlight, cause of lack of room behind the headlight housing.... 4. Bi-xenon is for car with both high and low beam on single bulb... Bi-xenon kit some with single HID bulb with sliding mechanism to act low and high beam by sliding in and out... Quote:
It has built-in filter and in-line resistor to remove the CLB(Check Low Beam) and flickering problem.... That one will be $280 shipped through this group buy.. normally $300 ![]() Quote:
- 4300k (Slight yellowish white) Maximum visibility - 6000k (Pure white) Most white with great visibility - 8000k (Bluish white) Little bit of blue with good visibility - 10000k (Blue/Purple) Most color but adequet visibility Quote:
GP will be untill Chinese New Year (2/18), but I might extend to end of February if the sales are good...
LEDmod.com [LED modified] Toll Free 888-477-4944 NEW Store Location in Buena Park, CA!!! Custom Gauge Face and LED Lighting HID Conversion Kit with Slim ballast Local installation service available in Southern California and Las Vegas Last edited by LEDmod : 02-05-2007 at 11:57 AM. |
#15 |
the warranty doesn't require the kit to be install by a professional does it??
#16 | |||
Sponsor
LEDmod.com [LED modified] Toll Free 888-477-4944 NEW Store Location in Buena Park, CA!!! Custom Gauge Face and LED Lighting HID Conversion Kit with Slim ballast Local installation service available in Southern California and Las Vegas |
#18 | |
Sponsor
- Single-beam Conversion Kit : $180 Paypal : Sean@LEDmod.com Please include which size, color temperature and phone number!!
#20 |
Hey Sean, my friend is interesting to buying your HID kit for his Integra '98. We think that he needs the 9006 for his low beams. Can you check if this is the right bulbs for his car? and if everything's ok i will pay you via my Paypal and you'll be able to ship it to my house, and i'll give it to him!
Bring me back on this! Thx
![]() Celica GT 2000, Short ram intake, Magnaflow exhaust w/o stock resonator, Full Vizage kit, TRD spoiler, CF raised hood scoop, S2000 Antenna, Custom painted gunmetal headlights, OEM fog lights, KYB AGX shock, B&G springs ,19" TRD wheels , 6000k HID,TWM short shifter and TWM bushings. |
#21 |
#48 Chino Hills '07
and these bulbs wont melt the headlight housings or harnesses would they??
#22 | |||
Sponsor
Yes, you'll get your tracking number in about 3-4 days... Quote:
As long as it's installed properly that is...
#23 | |
Sponsor
Purchase at your risk, since it will bother on-comming traffic.
#25 | |
Sponsor
But for our car, another set of HID has to turn on for high beam... it's bad for the ballast to turn on/off repeadly for flashing high beam... IF you aren't going to use high beam to flash people, then you can get the HID for the high beam... HID kit has warm up and cooling period, so you don't want to turn on/off fast..
#26 | |
teh sweetness
#27 | |
Sponsor
![]() I just want to inform you first before you jump on it...
#29 | |
Sponsor
Basically.. - Remove stock bulb - Mount the ballast - Install the HID bulb.. - Connect the input power to the ballast and ballast to the HID bulb. - Zip tie it together, so there is no loose wires... That's all.... There are easy way and hard way to do it.. - Easy way is installing without removing the headlight - Hard way is installing with removing the headlight.. You can install them either way...
#32 |
^ its $180 for a pair so you can do both sides, the bi-xenon thing is for if you have a dual filament bulb (high and low beam on the same bulb used by domestics a lot)
How are these on fog lights? or can you put them on fog lights? |
#35 |
sorry to jack the thread, but one of my buddies mentioned somthing about celicas coming stock with HID's at least a certain package? is there any truth to this?
#36 | ||||||
Sponsor
One of the example on 07 Camry (with 8000k) http://i21.photobucket.com/albums/b2.../Camry07-1.jpg I will take some picture on my car... (with 10000k) Quote:
Comeplete conversion kit... Quote:
I do believe they fit, but I think you might have to trim the cover little bit.... Quote:
http://www.newcelica.org/forums/showthread.php?t=235860 I don't sell them specifically for motorcyle iwth 1 bulb and 1 ballast.. But I can just send you just 1 bulb and 1 ballast from the kit... If you are intersted then just PM me.... Quote:
#37 |
Fried Tofu
so how much extra is 3000k? do you have it in h3 because im planning to put them on my fogs
__________________ __________________ __________________ __________________ __________________ |
#38 | |
Sponsor
#40 | |
Sponsor
#41 |
RuffRydersNYcelica
how much for fogs & headlighs....& its me again with the club...i didnt forget about the guages im discusiing somethings with state rep....basically i feel like if ima test subject for them it should be comin out the clubs pocket not mine...but as sson as everything is straightened out with that i will let u kno about the guages.... & i just saw this now but if u have all sizes for all cars id love to talk 2 my members & do a group buy with them if u could do that? Pm if thats easier for u
[IMG][img=http://img226.imageshack.us/img226/8862/mycar003xt9.th.jpg][/IMG] [img=http://img133.imageshack.us/img133/1083/davecelica005zi5.th.jpg] -Ruff Ryders N.Y Car & Truck Division- |
#42 | |
Sponsor
This is already really good price.. no minimum people needed for group buy... basically sale for celebrating Chinese New Year.... ![]() I have pretty much all sizes for the cars.. those sizes I've listed should cover most cars that doesn't use sealed headlight(like bulb and lense is together..) About the gauges, if everything works out with you and I get to knwo your club better.. I can work out a deal with your club no problem...
#43 |
RuffRydersNYcelica
ok that sounds great....ima try and call a meeting ask every if they want them.....and try and get in touch with the state rep again...cuz as far as i see it im doin the club a favor...so they should be payin lol....let me kno wat else u do..like wats on ur resume besides guages & hids....mayb we can work out more deals...& the state rep will feel a lil more comfortbale
#44 |
RuffRydersNYcelica
also if u have pics of all the diff temps....that would be good too
#45 | |
Sponsor
![]() I don't have much picture with different temperature, but you can refer to this picture.. It's for reference only, it will look little different in person, but you can ge the general idea..
#46 |
Sponsor
Installation Guide Added
| Thread Tools | |
| Display Modes | Rate This Thread |
