Old 04-10-2009, 01:59 PM   #101
2way
I was referring to the rattle. And thinking about it..... the OCV is duty cycled... that would explain alot. Low pressure, OCV switching on/off, pin releasing/re-locking = rattle till pressure builds up. It also explains why it stops if you disconnect the OCV. The pin locks.
But, that area on the gear will always wear because of the lock/release pattern.
2way is offline   View this Members' Photo Gallery Reply With Quote
Old 04-10-2009, 03:12 PM   #102
GSBoek
I know hehe, on the old oil pump, the new gear had a tiny bit of the rattle once in a while at idle. With the new oil pump I haven't heard it anymore.
Greed: Get more and more each day...yet never having enough.
Generosity: Giving each day... yet always having more than enough.
Old 08-21-2009, 10:35 PM   #103
choi0706
Send a message via AIM to choi0706
how much are these supposed to move when you apply power to them? I'm seeing only a small change in movement..
OCV
Smaller supercharger pulley for greddy kits
http://newcelica.org/forums/showthread.php?t=266218
Greddy brackets for sale BRAND NEW!
http://www.newcelica.org/forums/show....php?p=5524545
choi0706 is offline   View this Members' Photo Gallery Reply With Quote
Old 08-26-2009, 09:53 AM   #104
GSBoek
It's not much, maybe 1/4" or less.
Old 09-02-2009, 10:02 AM   #105
l3ksi
I have a 2000 celica GTS - automatic transmission
2 months ago my car was throwing an OCV malfunction code - P1693. When I went on a trip last month I left my interior light on, and I drained my battery. When I got home from my trip I recharged my battery and my engine check light was off. Ever since my battery drained itself, my car isnt throwing the code any more. Before when I use to rev over 6grand my car would throw the code. Now I can rev my car to 7grand and nothing happens.
I was going to order a new OCV from toyota and they quoted me 150.90 for the part, and 107 for an hour labour. Do i need to replace the part? Or since the code isnt coming up is it ok?
What is everyone's opinion on the matter?
l3ksi is offline   View this Members' Photo Gallery Reply With Quote
Old 09-04-2009, 02:45 PM   #106
GSBoek
If it ain't broke, don't fix it. If you can hit lift fine now just keep up with regular maintenance, specially oil changes. Only change it if it comes back.
Old 09-27-2009, 08:06 PM   #107
bamaboy1626
getting too old 4 this
anyone got the OCV part #s for a 2000 gt-s?
bamaboy1626 is offline   View this Members' Photo Gallery Reply With Quote
Old 09-28-2009, 06:30 AM   #108
2way
http://www.toyodiy.com/parts/
Find any part number you'd like.
'02 Celica GT-S/6 '96 Avalon XLS
'88 Camry DX Wagon '86 Camry DX Sedan '83 Corolla SR5 Liftback
'82 Ford LTD-S(351W HO) '79 Corolla SR5 Sport Coupe '76 Corolla Wagon
PCIA Certified Mobile Communications Technician
Old 10-08-2009, 09:23 PM   #109
bamaboy1626
what do the OCVs run. I think I got a really good deal here locally from Orielly. The girl there had to order it from Toyota, but she gave me her price.
Old 10-23-2009, 12:21 PM   #110
RekindledSpirit
I just checked my OCV... looks good, BUT my screen is stuck inside and from what I could see, it doesn't look like it's in good shape. Adding to my list of items to replace...
RekindledSpirit is offline   View this Members' Photo Gallery Reply With Quote
Old 11-03-2009, 09:22 PM   #111
farm
Well I'm getting the rattle sound too, so I tried to unplug my OCV wire to see if the OCV was actually the culprit.
Sound is still there, and doesn't seem to attenuate.
That means it's most likely the camgear/lockpin as you explained in the earlier posts ?
BTW, its normal that it's throwing a CEL after i unplug the wire?
farm is offline   View this Members' Photo Gallery Reply With Quote
Old 11-04-2009, 12:56 PM   #112
GSBoek
Yeah, the CEL is normal, it will reset itself after two or three startups when the ECU registers that everything is working properly.
Old 11-16-2009, 08:49 AM   #113
celi01
i'm getting the tractor noise now. it started randomly middle of this summer and is now constant at normal temp. would you say it is bad for the engine and the cam-gear should be replaced asap?
2001 GT 5 SPEED. AEM CAI. MAGNAFLOW EXHAUST. B&M SHORT SHIFTER
http://www.youtube.com/watch?v=lPmDknIT2bU
celi01 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-16-2009, 09:48 AM   #114
GSBoek
Let me put it like this: If the source is indeed the camgear you might get away with it for some time. I drove on my old one for 2 years. Usually when you unplug the OCV the noise should go away, regardless if it's caused by the OCV itself being faulty or the camgear being faulty.
Old 11-16-2009, 01:30 PM   #115
celi01
nothing happened when i unplugged it. and im throwing a buncha misfire codes now. idk if you can help me out there. so im trying to think is it actually the camgear? im putting up a video here shortly
http://newcelica.org/forums/showthre...wpost&t=308665
Old 01-20-2010, 07:03 PM   #116
gotlag1789
hey i have a question lol. sorry to randomly bring it up but this is the OCV. soooo i bought the car used. tried to hit lift ( this was back in november ) and i got a CEL, diagnosed it p1693. CLOSED OCV malfunction. i just cleared it because it was snowing and hitting lift on slush is death lol. but now i wanna fix it, tried it again yesterday and i got the same CEL p1693. ive taken off the housing and cleaned the little mesh screen with brake cleaner. and tried to take out the lift OCV but it didnt seem to budge. ^^ earlier in the post somebody mentioned that there are breather tubes that you gotta take off? and also. when i do get it out. just soak it w/ break cleaner? lol. and my car seems like its revving realllll high and loud. like when i get close to 6k it sounds like its gonna blow up. does the car do this b/ of the OCV not working? i honestly dont think its supposed to sound liek that.
gotlag1789 is offline   View this Members' Photo Gallery Reply With Quote
Old 01-21-2010, 11:46 AM   #117
GSBoek
The breather tube removal is for the timing OCV (next to the alternator). The lift OCV should come out of the housing when you remove the 10mm nut holding it in place. If it's stuck to the housing you probably have sludge buildup in the housing/OCV, conceivably this could be causing the P1693. You need to take the OCV out of the housing and test it to see if the plunger is moving both ways. Many times it's not enough to just clean the filter, you need to clean the whole housing and OCV. I wouldn't use brake cleaner on the OCV though.
Old 01-21-2010, 04:58 PM   #118
gotlag1789
^^ oh alright thanks a lot man. yeah from reading all of this im hoping thats all it is, the buildup of junk in there. what do you suggest cleaning the housing and OCV with? and as for the car drivin like 3k is 6k is that normal w/ an OCV malfunction?... lol
thanks man
Old 01-21-2010, 05:16 PM   #119
JameX
Greddy Supercharged
thanks man
Diesel.
JameX is online now   View this Members' Photo Gallery Reply With Quote
Old 01-22-2010, 06:12 AM   #120
gotlag1789
diesel? lol. alright. sounds good. tearin it down tonight. fill you guys in on what happens
Old 01-22-2010, 09:28 AM   #121
2way
or kerosene
Old 02-01-2010, 10:59 PM   #122
6strngs
I just replaced both my filters tonight. Got both of them from 1sttoyotaparts.com for about $9 + shipping so I figured I'd just replace them instead of cleaning them.
I didn't know that when you remove the lift OCV housing a bunch of oil comes out of it! Spilled oil all over the back of my engine... hopefully it'll burn off on it's own cause I couldn't really reach my hand back there to wipe much of it up. And the timing filter would've been pretty easy, I just took the belt off and top bolt out of the alternator and loosened the bottom bolt which allowed me to move the alternator about 2-3 inches and gave me more than enough room to get a wrench in there and get the filter out. Unfortunately the O-ring that's on the bolt fell off into the abyss and I spent over an hour looking for it. Eventually ended up pulling the whole alternator to find it. But it was all a waste of time because the filters were both perfect without so much as a speck of dirt on either. I guess frequent oil changes with good oil and filters really will make them last forever without the need for cleaning (i'm at 90K btw)
Anyway, just want to thank you for the guide, I wouldn't have even known those filters existed without it
00 Celica GTS 6-speed - SOLD!
69 Pontiac Lemans - new project car/gas guzzler
04 Subaru WRX - new toy and daily drive
6strngs is offline   View this Members' Photo Gallery Reply With Quote
Old 02-05-2010, 05:12 AM   #123
Lupo
Maybe someone can help me.
[Error P1349]
I've found my OCV broken into its housing.
I'm afraid something else could be damaged into the engine head .
Lupo is offline   View this Members' Photo Gallery Reply With Quote
Old 02-05-2010, 05:37 AM   #124
GSBoek
Ouch, I'm afraid the only way to get everything out is pulling the head. This is probably the first broken OCV tip I've seen.
Old 04-13-2010, 05:15 PM   #125
Pocket Rocket
is it really necessary to replace these - unless you really neglect your oil changes? or do you get a bit of residual sticking over time - i use flush but thinking the lift one will never get cleaned so maybe they are worth replacing/cleaning? i'll inspect mine and if i find anything i'll post some pics.
PRP Intake & Exhaust Manifold, PRP 68mm TB, Hondata IMG, TRD CAI, Eibach Pro Kit, TRD(JP) FSB, Yamaha RSB, Bridgestone Potenza's, TRD(JP) Black Pads, TTE Front Splitter, TTE Rear Bumper Extension, TTE Side Skirts, TTE Rear Spoiler, 35w 6K HID's, LED Sidelights, DRL LED Foglight Conversion, Team Heko Wind Deflectors,Leather Interior, Custom Toyota T Sport Mats, TRD Shift Knob,Red Led Conversion
MWR flywheel, Apexi filter, Helix Cermetallic paddle clutch w/ uprated pressure cover ordered
Pocket Rocket is offline   View this Members' Photo Gallery Reply With Quote
Old 04-14-2010, 01:41 AM   #126
ungeeked
Camry
Hi All..
I drive a Camry and my car started showing up P1349 a couple of months ago.. initally, the CEL came on and went off.. but now its on permanently.
I took it to the dealer and he said he wud need to replace the camgear (without checking much).. and gave me an estimate of $650.
I have never worked on a car before. This is my first car. Naturally I want to avoid screwing it up.
Firstly, I want to know is there anything I can do to clean up the OCV without actually taking anything apart? Any additives to the engine oil or anything without taking stuff apart? Even if such solutions are temporary, I would be glad to know.
IF NOT, then do I need to take the whole engine out of the car to replace the OCV? Or is just a few screws and I can reach out for the OCV easily?
Also, since I am a first timer, should I be trying it out myself?
ANY HELP IS DEEPLY APPRECIATED
PS. I am sorry for my really novice language.
ungeeked is offline   View this Members' Photo Gallery Reply With Quote
Old 04-14-2010, 01:49 AM   #127
farhanali89
Send a message via AIM to farhanali89 Send a message via MSN to farhanali89
Usually if you keep up with your oil changes the OCVs should be fine. Its the screens for the OCV which you want to clean to avoid them getting clogged up. There small plastic mesh things.
Its advised to clean them if you dont keep up with regular oil changes.
I recently did mine around 4 months ago and i didnt find anything unusual.
Originally Posted by ungeeked View Post
Hi All..
It is not to difficult to change them really but if you are not confident in carrying out the repair yourself then i would leave it to a professional.
Usually there is one bolt holding the strainer and one holding the actual ocv, im not sure where they are located on your car but i know usually on the right side of the engine head is most probably where the ocv should be on your car.
On the 2ZZ-GE we have the Lift OCV on the alternator side and a VVT ocv on the right side of the head.
ZZE123R - Facelift Corolla T-Sport 2ZZ-GE VVTL-I
Originally Posted by GSBoek View Post
I really don't know, I just squeezed and played with the whole thing until I got it to fit. I think the filter itself was close to 8".
farhanali89 is offline   View this Members' Photo Gallery Reply With Quote
Old 04-15-2010, 03:17 PM   #128
Gravel
Hi guys - I hope you can help me with my sickly 2ZZ - I guess my question might be better in the lift-diagnosis thread, but that's locked...
Anwyay, I seem to have lost lift (I can't hear it and my boost pressure is double what it should be above 6200 rpm)...
I have no CELs - or pending CELs.
I tried the 'manually fire up the VVT-L OCV and stall the engine test', the engine nearly stalls, but then recovers and runs roughly. I decided to call this a fail, so I bought a new OCV, filter and gasket, and replaced all three. Repeated the test, and the car still won't stall, and has no lift when driven. The VVT-i OCV also seems to affect idle when manually fired, so it's moving too.
I've had the cam-cover off, and replaced the lift-bolts which were fine anyway - didn't notice any damage to rockers or cam wear, but didn't really check too hard, just took some pics.
As the ECU is happy with the oil-pressure when the OCV activates (and throws CEL's during my manual activation of it under idle), it would seem there is plenty of oil in the VVT-L OCV. Can it my rocker-shafts be full of enough sludge to disable lift? And if so, what can I clean them out with, without simply forcing all the sludge into the engine?
Cheers.
Gravel is offline   View this Members' Photo Gallery Reply With Quote
Old 04-15-2010, 03:58 PM   #129
2way
Sounds right.
Check/
Can you go above 7K??
Have you seen sludge evidence elsewhere? I believe Gio advised that you could clean some of the passageway from the VVTL OCV w/a pipe cleaner. But, if you pulled the VVTL OCV and cleaned, you'd have certainly seen any evidence of sludge there.
Are you running an aftermarket oil pump? Any leaks on the turbo oil cooler or turbo? Although, if this were the issue, you would think it would pop an OCV CEL.
Sounds either mechanical (lift bolts, rotated rocker arm, something valvetrain broken (like a slipper follower), or its oil pressure related in the head beyond the pressure sensor - plugged passageway or cockeyed rocker arm, too much rocker arm slop, etc.
I drive a Camry
V6 from the sludge prone years?
Hell no!
Old 04-15-2010, 05:03 PM   #130
Gravel
Hi 2way, thanks for the reply!
Originally Posted by 2way View Post
Sounds right.Check/
Yes - I can go all the way to 8000+ rpm...
- No sludge, I did clean my OCV filter when I checked the lift bolts, but there was nothing much on it. Replaced it anyway when I changed the OCV - they're just
Old 04-15-2010, 05:22 PM   #131
farhanali89
[QUOTE=Gravel;5024842]Hi 2way, thanks for the reply!
Old 04-15-2010, 06:46 PM   #132
2way
Sounds like you've got lift, then. Unless the S/C can push you that high on the lower lobe.
Old 04-15-2010, 08:04 PM   #133
'01gtcelica
how much did a new vvti actuator cost you GSBoek? is there a way to check if i do need a new one? my engine has the tractor noise, and it doesnt go away when i unplug the ocv. the screen was clean, and when i applied power to the ocv my engine stalled almost immediately. if it stalled does this mean the cam gear is still good, or can it still be whats causing the ticking? thanks alot in advance.
2001 LS Celica GT 5MT
'01gtcelica is offline   View this Members' Photo Gallery Reply With Quote
Old 04-16-2010, 12:31 AM   #134
Gravel
Originally Posted by farhanali89 View Post
if you have a moment i posted this diy thread up a few weeks ago. Someone had a lift problem a while back down here.
http://www.newcelica.org/forums/showthread.php?t=315534
have a quick read and if you get a moment pull off the rocker cover and have a look for the signs it may allow you to cancel out a larger problem if its not things you have already checked
Thanks - that was the closed thread I would have liked to have posted in!
I didn't see any cam/rocker damage when I changed out the slightly worn but intact lift bolts, but it sounds like I could have broken rockers and not be able to tell without feeling behind them. I guess this means removing the camshafts?
Old 04-16-2010, 12:35 AM   #135
Gravel
Well actually, it really doesn't 'sound' like there's any change over at 6x00 rpm - you can run without boost at any rpm on the s/c if you use part-throttle, and there is no change of engine note around where it should enter lift
The data-logs I get also show that rather than the boost pressure dropping suddenly as I transition into lift, as it used to, it does infact climb - suggesting that I'm still on the low cam.
Old 04-16-2010, 01:28 AM   #136
farhanali89
Ah damn i see, yes i asked a moderator to pin it up as a read through so that maybe why no one can post in it.
It is very possible that the lift bolts may still be intact but wont indicate a broken rocker, The individual whos vehicle was suffering the lift problem only noticed marks on the camshaft lobes. I would have a proper look on the lobes, Rub a nail through to see if you can feel any irregular grooves.
It is definitely possible the rockers could be broken. If you have caught this early im sure it wont be to large of a job, The member had to have a head rebuild because the problem was present for so long and it ended up bending a valve.
If you have any luck in checking let us know and i hope its not to big of a problem.
Old 04-16-2010, 05:35 AM   #137
2way
Yeah, that part was bothering me too.
Any issues in the data logs w/temps? Stock ECU w/management or aftermarket ECU? If a stock ECU thinks the engine isn't to temp, it won't switch over and won't pop a CEL. Which would also go in line as another possible problem. Everything would physically check fine, as is your case, but not engage the 2nd cam in actual driving.
Old 04-16-2010, 11:50 AM   #138
Gravel
The logs show sensible looking water temps, and I would have thought the rev-limit would be stuck at 7000 odd if the ECU thought the car was cold?
I'm running the stock ECU + Emanage Ultimate, so I shouldn't have messed with the valve-timing at all.
It's quite possible that my ECU is the problem, but I can't rule out something mechanical either as I can't completely stall the engine by firing the lift-OCV manually. The diagnostic guide (DI-140) just says "Check the engine speed - OK, Engine Stalled." but says 'stalled or rough engine speed' when you fire the OCV via a magic Toyota hand-held tester
I am half tempted to splice in an LED and resistor on the OCV signals and see if it lights up when I hit 6200 rpm - can't really do that on my driveway!
Old 04-16-2010, 11:54 AM   #139
Gravel
Cheers - I think I may try and clear out the garage enough to get the Celica in, and take the cam-cover back off over the weekend.
Old 04-16-2010, 12:08 PM   #140
2way
Yes, you can. You don't have to be in gear to switch over to the 2nd cam.
I don't think it rev limits in the case of it being cold. It just stays on the small cam. With the S/C, you're probably able to go beyond a N/A on that cam.
Old 04-16-2010, 12:36 PM   #141
Gravel
LOL, no I meant I can't get away with doing that on my driveway - gf and neighbours would not be impressed and my ears would be bleeding if my head was under the bonnet monitoring the OCV signals
I could be wrong, but the few times my car's been too cold for lift, it's felt very much like a fuel cut at 7,000 rpm
Old 04-16-2010, 12:46 PM   #142
2way
I don't recall... so, it may be the case. If true, then you are definitely looking at something mechanical or oil related.
Old 04-16-2010, 09:26 PM   #143
'01gtcelica
hey do you guys have any suggestions for me?:]
Old 04-17-2010, 07:13 AM   #144
Gravel
I just had an idea - as my new VVT-L OCV didn't fix anything, and the old one works fine, I decided to try driving with the old-OCV connected to the ECU so that even if it tries, it can't engage lift.
The result was that the car felt pretty much the same, but the moment the car hit about 6200 rpm, I got a 1683 CEL - as the ECU had tried and failed to operate the Lift-OCV. So it looks like this really is an oil/mechanical problem somewhere beyond the Lift-OCV...
Time to take the lid off the engine again...
Old 04-17-2010, 07:57 AM   #145
2way
Buy a GT-S & double your trouble. Actually, where you have a '01 GT that may be subject to oil burning and your description - I'd suspect you've got rod knock.
Lucky you
Old 04-17-2010, 11:34 PM   #146
'01gtcelica
Lucky you
actually, i have had her go dry on me before, and had to change the rod bearings. the bearing on cylinder no.1 was scratched and scored a little bit causing the knock, and the crank was still good. havnt had a knock since then, and i know what it sounds like. i have been checking the oil almost every other day, and go through 4 quarts every 2500 miles now. but this definitely sounds like the valves. would a worn vvti actuator cause this noise?
Old 04-18-2010, 06:53 AM   #147
2way
If you're not already, switch to a high mileage oil.
Possibly oil starvation to the VVT?
Old 04-18-2010, 08:50 AM   #148
Gravel
Well, I've taken my cams out - they look and feel fine, all the rockers look & feel fine, and the valves look fine as far as I can see! I will take a shed load of pics though...
What would happen to the valve-timing if the ECU thought there was a shed load of knock going on?
Old 04-22-2010, 11:43 AM   #149
'01gtcelica
im currently using mobil1 fully synthetic 10w-30 high milage with a high milage filter, nothing seems to help. looking for a 2zz to swap lol.
what exactly do you mean by oil starvation to the vvt? how do i check? and it hasnt ran more that a half a quart low since september when i had to drop the pan. and the noise just started maybe a month and a half ago.
Old 04-22-2010, 03:47 PM   #150
Gravel
So, I've just put my engine back together - couldn't see anything wrong with the cams, valves or rockers. I still have no lift, but no CELs...
What do I check next? I'm really stumped
ocv, oil control valve, vvt-i, vvt-i noise
