I want to know what are the best spark plugs to get
Probably IK24s for a 75 or 50 shot, IK22s for a 35 shotjonasblack said:I have heard that when you instal nitrous you need to run cooler plugs.
Which plugs are those?
got a item number?
Actually, the stockers are Denso Ultra Long Life Iridium versions (the electrode tips are slightly larger & less brittle than the IK's - 0.7mm vs. 0.4mm)... for a GT-S = Denso SK20R11. They last longer & are less expensive (around $8 ea. with a 60K change interval... but have been known to last up to 120K) than the IK's.Jesse IL said:The GT uses Denso IK16 stock, the GT-S uses IK20 stock.
2way said:Actually, the stockers are Denso Ultra Long Life Iridium versions (the electrode tips are slightly larger & less brittle than the IK's - 0.7mm vs. 0.4mm)... for a GT-S = Denso SK20R11. They last longer & are less expensive (around $8 ea. with a 60K change interval... but have been known to last up to 120K) than the IK's.
The IK20's will give slightly better performance... but won't last as long ("Because gradual wear will
:thumbup:bebe said:i got mine from karacing(trd denso iridium ik22). very good!!!
IK's smaller center electrode "reduces the voltage requirements, concentrating its sparking power. Also, its smaller size, combined with the tapered U-Groove ground electrode, allows more room for the flame kernel to develop and produce a more efficient combustion." But, its smaller center electrode is also the reason why the change interval is quicker.danGTS said:Why ik is supposed to perform better?? plate design, gap, metal used?
Ryude said:They also don't have to be gapped.
Not likely.saccelica916 said:nubby ass question but o well... i have an 03 gt. would i get a hp gain from plugs?
:werd:6speedGTS said:But it is good idea to check them before installation.
:werd:Boosted2.0 said:Not likely.saccelica916 said:nubby ass question but o well... i have an 03 gt. would i get a hp gain from plugs?
What about NA? No noticable timing increase possible I assume from your comments? So still, ik-20 or sk-20 will do the job perfectly for NA?Boosted2.0 said:Yup. You can gain power from plugs with FI, only in that they aloow you to run more timing without detonation, but thats the tune making the power not a difference in the plug itself.
They can be useful on a full boogey NA 2ZZ motor with power FC, but a GT with bolts ons wont profit.danGTS said:What about NA? Not noticable I assume from your comments? So still, ik-20 or sk-20 will do the job perfectly for NA?Boosted2.0 said:Yup. You can gain power from plugs with FI, only in that they aloow you to run more timing without detonation, but thats the tune making the power not a difference in the plug itself.
Thanks!
